Jaya_sk
gear fit2 burn
JUMP TO SOLUTION
Hello,
I have recently purchased a Samsung gear fit 2 pro and am experiencing some rash and itchiness just below the heart monitor.
I would like to have someone address this issue especially because it is a very useful device .
1 SOLUTION
Re: gear fit2 burn
JUMP TO SOLUTION
Will you please send a private message with the full model code and serial number so that I may look in to this for you? http://bit.ly/2XERsky
2 REPLIES 2
Re: gear fit2 burn
JUMP TO SOLUTION
userAXVyG8JCi2
Re: gear fit2 burn
JUMP TO SOLUTION
I have had the same problem, it also overheats
