gear fit2 not found on s21 ultra
(Topic created: 02-26-2021 02:48 PM)
userqImkZSfdol
Gear and Gear Fit
Disconnected from old phone but is not found by new one
nopen1278
Sun
Gear and Gear Fit
Resetting the watch may help. Some users had to reset the watch a few times to get it to connect.
nopen1278
Sun
Gear and Gear Fit
userqImkZSfdol
Gear and Gear Fit
think I got it
SamsungQue
Honored Contributor
Gear and Gear Fit
An Accepted Solution has been marked and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. If you have a separate concern, feel free to post again or send one of our moderators a private message with more details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed to keep our community organized and make it easier for our users to find resolutions and needed content. Remember that if you do make a post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring with your product. Thank you for being part of the community!
