gear s3 - invalid utf 8 error
(Topic created on: 2/3/19 9:49 AM)
userYd9z7hZ252
Gear and Gear Fit
after updating my phone to android 9 i get "invalid utf 8" error instead of the name of the caller. i have resetted both, my phone and my gears s3 watch without solving the issue. need help.
SamsungZell
Gear and Gear Fit
Repairs would be recommended. Can you please send us a private message with the below information here: http://bit.ly/2GH8URL
First and Last Name:
Property Address:
Email Address:
Phone Number:
Alternate phone Number:
(15) Digit IMEI Number:
Model Number:
SamsungZell
Gear and Gear Fit
Does the issue occur when the device is being ran in safe mode?
You can locate the steps to place your device into safe mode here: http://www.samsung.com/us/support/troubleshooting/TSG01001188/
userYd9z7hZ252
Gear and Gear Fit
i have no idea how to turn samsung gear s3 frontier in safe mode. it's a smartwatch.
SamsungZell
Gear and Gear Fit
Safe mode on your mobile device that sends the contact caller display to the watch. What type of phone are you using? We can provide you the steps if it's a Samsung model.
userYd9z7hZ252
Gear and Gear Fit
i have checked with my phone in safe mode. the same issue. when i recieve a message , the sender name it apears on my watch. also the caller's name after the call
SamsungZell
Gear and Gear Fit
Property Address:
Email Address:
Phone Number:
Model Number:
userYd9z7hZ252
Gear and Gear Fit
i am still waiting for a solution, if somebody knows one. thank you!
userCXn0d3kmkV
Gear and Gear Fit
This issue IS NOT SOLVED!
Sapalex
Gear and Gear Fit
Same issue, after update to Android 9.0
SamsungJoJo
Gear and Gear Fit
@Sapalex
Hello,
What troubleshooting steps have you already tried?
