Highlighted
gear sport won't turn on after update yesterday
hello every one i have a gear sport for a while now after the update that roller yesterday with bixby the watch was supper laggy and i couldn't even connect it to my phone because the setting were not working i couldn't even turn the watch off so i let it dry from battery and left it to charge  over night now it cant be turned on again when i put it on the charger and pres the power botton i see samsung gear for a moment then nothing. what to do ?
regards
4 REPLIES 4
Highlighted
Re: gear sport won't turn on after update yesterday
If your watch's battery is completely discharged, it will not power on. You'll need to charge it before turning it on. If the watch will not power on or is running low on battery and doesn't seem to charge, the problem could be anything from the battery, connection, the charger, or the watch itself. Give this link a try: https://www.samsung.com/us/support/troubleshooting/TSG01003100/
If you continue to experience these symptoms after trying the troubleshooting steps provided, I would recommend a service repair. Can you please provide me with the following information in a private message: http://bit.ly/2JH2rq2
Full Name:
Street address:
Email Address:
Best Contact Number:
Alternate Telephone Number: (If Available)
Model Code:
Serial/IMEI Number:
Highlighted
thanks @SamsungAdam  for your reply i tried zith different charger but the same issue, and i tried the link you ve sent no progress, i ve sent you a message regards
Highlighted
Hello again,
I just wanted to check in to see if you still need any assistance?
Highlighted
@SamsungJoJo  hi, the problem is still here, my watch was woking fine before the update now it doesnt power on or show charging icon at all
