gear sport
(Topic created on: 1/9/21 4:15 PM)
KrashKiten
Gear and Gear Fit
Wont connect to my galaxy s20 for some reason after recent update. What gives
1 Reply
DGM
Nebula
Gear and Gear Fit
I think your best bet will be to uninstall the Galaxy wearable app and then reinstall it. Good luck!
Be sure to click " ✓ Accept as Solution" when you find an answer that works for you. - Thanks!
