- Mute
11-11-2020 02:33 AM (Last edited 12-04-2023 12:04 AM by SamsungChelsea ) in
Gear and Gear FitThe screen on my gear s3 suddenly was gettingblines across it. It eventually died but a few days later it came back on. But I can only see half the screen. Unless I turn the brightness up to 10 aNd then I see it but it's far too bright.
Solved! Go to Solution.
- Mute
11-16-2020 08:22 AM (Last edited 01-19-2023 12:24 PM by SamsungRei ) in
Gear and Gear FitHello, We know how disappointing it is when the screen is not displaying correctly. We recommend taking a look at the newest Samsung Watches available, as the Gear S3 has reached the end of support. https://www.samsung.com/us/watches/
- Mute
11-14-2020 03:58 PM in
Gear and Gear FitHave you tried these troubleshooting steps here?
- Mute
11-14-2020 04:31 PM in
Gear and Gear FitI have tried rebooting, reset, factory settings, etc. I just can't get the screen to.look normal when it has finished starting up. When it first turns on and there is no face just the logos or the reboot menu it looks normal. it's when it's finished and starts to show.the time I just get half the screen. unless the brightness is at 10. which is too bright but it clears the block.
- Mute
11-14-2020 04:44 PM in
Gear and Gear FitCan you send me a private message using this link here? (http://bit.ly/2HP0oRi) Provide the following information.
- Model number
- Serial number
- Mute
11-15-2020 02:49 AM (Last edited 11-16-2020 08:21 AM by SamsungAdam ) in
Gear and Gear Fithi
model number - SM-R770
serial number - <hidden serial number>
- Mute
