Highlighted
sensor stopped working
all of a sudden it won't measure heart rate or do a workout. I went for a run stated workout it counted down 321 then it just stopped working. It measured my steps but that's all. I turned watch off and restarted it but still does not work.  I have an error measure saying clean sensor so I done that still not working.Can you help me please.
5 REPLIES 5
Highlighted
Re: sensor stopped working
Thank you for reaching out, I recommend having the watch evaluated by a certified technician, I will be happy to look into those options for you. Please send a private message with the full model code and the serial number/IMEI number of the watch. http://bit.ly/2XERsky
Highlighted
how do i find my mdel and EMI number
sensor not working. Been asked to give model and EMI code.
Highlighted
Re: how do i find my mdel and EMI number
What type of device are you trying to locate the full model number and IMEI for?
Highlighted
I have samsung fit pro
Highlighted
This information can be found in the Wearables app under the About Watch option or on the back of the watch in small print.
