55" Class 8000 Series LED 4K UHD Smart Tizen TV
(Topic created: 12-11-2021 07:19 AM)
userFSm1t99NKU
HD and UHD TVs
I just purchased this tv brand new. On the second day it started making clicking noises while it is off.
This is not related to temperature change. The clicking goes on all night long. The only way to stop it is to unplug it. When I plug it back in, the clicking starts again.
Other than that, it appears to work just fine.
Besides calling the store where I bought it to replace or return it, any other ideas?
userFSm1t99NKU
HD and UHD TVs
I did end up returning the TV. I also tried another one of the exact model which I also returned.
Apparently, based on the reviews on the retailer's site, I would say there is a manufacture's defect or a bad batch.
I ended up buying a different brand. Thanks.
SamsungTam
HD and UHD TVs
Hello! I completely understand your frustration with the TV making a clicking sound and it's only been two having the unit. If it is not related to temperature changes or if the unit has proper ventilation. I would honestly recommend contacting the local retailer to see your options.
userFSm1t99NKU
HD and UHD TVs
