Antenna connection not recognized?
(Topic created: 01-26-2020 11:24 AM)
WWW-NJ
HD and UHD TVs
Trying to set up an external antenna to access regular broadcast stations to my Samsung TV (un55mu7000f) and I am not seeing the option to access it.  According to the guide, I should be able to click the "Home" button on the remote and then I should see a "Live TV"option - but I do not see that. Choosing "Source" from settings doesn't give me any choices for antenna either.  Any help would be appreciated.
JUMP TO SOLUTION
SamsungJam
HD and UHD TVs
Fantastic!  We're glad that you found a resolution!
userfMRui6p49a
HD and UHD TVs
There is not a menu button on our remote
Not applicable
HD and UHD TVs
I will be happy to look in to this for you. Please provide the model number for the television.
useroQNdCYRR4x
HD and UHD TVs
HI
Have the same prob, and I see the TV !.
cheers
user3JMRHcaioT
HD and UHD TVs
Hello my broadcasting option is not enabled in the menu. I also only have TV+ under TV in the source options. I have the antenna plugged up and it also doesn't have the "Live Tv" option
userSGgOJKKkyC
HD and UHD TVs
Hi, I am also having the same issue as described above.  I have a 75 in Samsung - QN75Q8B.  Any help is appreciated.
