Connect 2 bluetooth headsets same time. TU7000 TV
(Topic created: 05-02-2021 05:09 AM)
userbESYa5rlNy
HD and UHD TVs
Can I connect two bose headsets via Bluetooth on a TU7000 TV? Each will connect independently with no problems.
SamsungCaleb
HD and UHD TVs
No this is not possible, you can find more information using the link below,
https://www.samsung.com/us/support/answer/ANS00085342/
1 Reply
SamsungCaleb
HD and UHD TVs
