userxO1jxmDXyT
Difference Between RU7100 and RU7200
JUMP TO SOLUTION
Will someone please tell me the difference between Samsung TV model numbers RU7100 and RU7200?
Thanks for the help,
Ron
1 SOLUTION
Re: Difference Between RU7100 and RU7200
JUMP TO SOLUTION
That is correct.
5 REPLIES 5
JUMP TO SOLUTION
It looks like the RU7200 model is just a store brand model and that's basically the only difference. The information I was able to pull up; The RU7200 model is a Wal-Mart specific TV of Samsung.
userxO1jxmDXyT
JUMP TO SOLUTION
Thank you for helping me out.  So, there would be NO difference between the RU7100 and the RU7200?  In other words the R7200 isn't a scaled down RU7100?
Thanks!,
Ron
JUMP TO SOLUTION
You are welcome.
userxO1jxmDXyT
JUMP TO SOLUTION
Thanks!,
Ron
JUMP TO SOLUTION
That is correct.
