Mandyg1979
Digital TV Antenna issues- Broadcasting greyed out
JUMP TO SOLUTION
My TV model # is  UN65MU8000FXZA
I'm trying to hook up a digital TV antenna and the Broadcasting setting is greyed out on my TV.  For some reason it's not picking up that the antenna is connected.  I've tried disconnecting and reconnecting the antenna.  I've also tried turning off and uplugging the TV.  Nothing has worked.  I tried it on our other Samsung TV and it works fine.  The antenna is working, is it possible it's not compatible with my TV.
Thanks for any help!
1 SOLUTION
Cookie-mon
Re: Digital TV Antenna issues- Broadcasting greyed out
JUMP TO SOLUTION
Hi Mandyg1979,
1. Power on TV and wait 5 minutes, do not press any button.
2. Disconnect TV from power and connect after 2 minutes
3. Press Home then go to Source, pick TV.
4. Open Settings then see if Broadcasting is available.
*Antenna should be connected throughout this process.
Regards,
Cookie
11 REPLIES 11
JUMP TO SOLUTION
That is a possibility.   Is all of your software and what-not up to date?
Mandyg1979
JUMP TO SOLUTION
Yes.  I forgot to add that. I did make sure my software was updated.  I'm starting to think more and more that it isn't compatible unfortunately.
JUMP TO SOLUTION
More than likely it's a compatibility issue.
Mandyg1979
JUMP TO SOLUTION
Off to shop for a new TV antenna.  I will update this post if it fixes it or not.
Thanks!
Cookie-mon
JUMP TO SOLUTION
Hi Mandyg1979,
Regards,
Cookie
Mandyg1979
JUMP TO SOLUTION
Thanks Cookie!  This worked!
I think the thing that was throwing me off was I wasn't selecting TV when I was trying to go to the broadcasting option in settings because it's labeled TV Plus and I thought it was just another app on the TV.
Hopefully this will help anyone else having trouble.  Thanks!
usermaUxv0K8Qf
JUMP TO SOLUTION
Thank you! I struggled with the same issue. Once I went to TVplus I was then able to select “broadcast” and scan for channels. Whew!
user0ZfG7gkS4T
JUMP TO SOLUTION
I tried it, but it sisn't work, Maybe the antenna signal is weak.  There should be a Smasung QLED FAQ  on TV problems with answers.  The people who program the smart TV know the conditions required to allow the "Broadcast" setup.
userw83G6JIvkf
JUMP TO SOLUTION
Hi,
I'm also trying to connect my Tv to the antenna. I tried all of these steps and none of them worked. The auto program is also greyed out in the options. Is there anything else I can do in order to connect the antenna. I have a Magnavox Mc346 indoor antenna Im unaware of my TVs model # but it is a smart tv
