Digital audio output connector doesn't match male
(Topic created on: 1/18/21 12:58 PM)
Manzanita101
HD and UHD TVs
I have a UN55C8000XFXZA Samsung TV, and just bought a Sonos Playbase to hook up for audio.  The output plug labeled Digital Audio Output on the TV on the TV doesn't look like it's a common female for Digital Audio male connection.  See photo.  I've got a round surround on the TV and the male has a different shape surrounding it.
Is it perhaps a mini digital audio?  Any suggestions on what I need to do to connect?digital.jpeg
SamsungGill
HD and UHD TVs
You may no longer have the box but the television originally came with an optical adapter like this one:
1 Reply
SamsungGill
HD and UHD TVs
