How to change volume of my wired headphones connected to UA43R5570AUXXL+?
(Topic created on: 3/12/20 11:48 PM)
Husain
HD and UHD TVs
I recently gifted my grandfather a new TV UA43R5570AUXXL+ and connected the headphone using a digital audio output to aux converter but the volume is extremely low and the remote is not able to control the volume of the headphone.
I cannot use bluetooth headphones as it needs to be connected again and again as you switch off and on the tv and my grandfather is not that technologically advance to do it himself.
please help me as to how should i increase the volume of my headphones.
SamsungAl
HD and UHD TVs
Regrettably, support for non-US models is very limited. We suggest reaching out to a support team in your area for further assistance. You can do so by using the following link: http://www.samsung.com/visitcountry
1 Reply
SamsungAl
HD and UHD TVs
