Highlighted
Led smart tv has a vertical band of white horizontal flickering
1 REPLY 1
Highlighted
Re: Led smart tv has a vertical band of white horizontal flickering
Does it happen on all sources? Does it happen on the picture test? Can you provide pictures of the symptoms you're experiencing?
