Highlighted
Lost picture and sound in Samsung UN50H6201 TV
JUMP TO SOLUTION
I have a Samsung UN50H6201  50" Smart TV which has lost picture and sound unexpectedly.  The unit has power; as identified by a faint raster.  Commands such as the menu or otherwise actived by the remote or on-board joy stick do not appear on the screen; nor do any of the video inputs.  I have power cycled the unit; to no avail.  The TV is in an indoor, climate controlled environment with little dust. I purchased this unit new several years ago; and has worked perfectly up until now.  I appreciate any support that can be provided.
1 SOLUTION
Highlighted
Re: Re: Lost picture and sound in Samsung UN50H6201 TV
JUMP TO SOLUTION
I recommend letting a service technician have a look. Send your full model code and serial number via private message to get started.
4 REPLIES 4
Highlighted
JUMP TO SOLUTION
Check this out, this may help alot.
https://youtu.be/xUzCLgoSPGM
Highlighted
JUMP TO SOLUTION
Thank you.
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
