Low volume using Bluetooth headphones
(Topic created: 08-19-2021 02:44 PM)
userOfT2eE9Je6
HD and UHD TVs
When I use Bluetooth headphones watching Samsung tv UN55RU7100FXZA, My volume is only about 30% and won’t go any higher
1 Reply
usere2ZkQzPZwQ
HD and UHD TVs
Here is a few things to try, enable developer settings and then disable absolute volume. Next try and increase the volume on TV and the phone. Finally make sure that you don't have the parental lock limiting volume with headphones turned on.
