Highlighted
NU7100 firmware 1202.3 update has caused power-on/blank screen issue
JUMP TO SOLUTION
Since the latest firmware (1202.3) my 55NU7100 has developed an issue. Basically, if using HDMI 1-2-3, when I power on the TV, I get a black screen (no smart hub/no picture). The TV is on, I can hear sounds when I press remote buttons, but the screen is not showing a picture.
The solution to temporarily fix this issue is to turn the TV back off & on OR to power on the TV by pressing a channel button (instead of power button) which launches into the DTV, that doesn’t exhibit the blank screen issue (experienced when using HDMI 1-2-3). It seems the latest firmware brought with it a HDMI handshake fail problem.
I thought I’d check to see if anyone else here is having this problem &/or has found a solution. A few people on avsforums/rtings.com have indicated they have the same issue since firmware 1202.3, on both the NU7100 & NU8000. I've contacted Samsung but they won’t allow me to rollback the firmware and won’t confirm if/when a new firmware will come and if it does, whether it will address this problem.
1 SOLUTION
Highlighted
Re: NU7100 firmware 1202.3 update has caused power-on/blank screen issue
JUMP TO SOLUTION
FW 1251 arrived today (in Australia). I have given it a few tries & at this early stage, it appears the power-on/blank screen issue is not present. I will test it out over the next few days and see if the issue has been fully rectified. I'm keen to hear from others.
24 REPLIES 24
Highlighted
JUMP TO SOLUTION
Surprisingly, this exact issue happened to me right before the update. I actually was going to update in hopes it would solve the issue, but it seems like that's not going to be the case. Hopefully there will be a fix soon. When it first happened, I got freaked out my 2 month old TV just died on me.
Highlighted
JUMP TO SOLUTION
It appears this issue has already been reported in this thread, albeit for a NU8 series TV. Reading thru the varous threads, it seems the issue occurs across all Samsung 2018 TVs (NU7, NU8, QF series). There is a "fix" suggested, although Samsung told me if I attempt it myself, it would void the warranty. Let's hope they push out a firmware update shortly.
https://us.community.samsung.com/t5/4k-8k-and-Other-TVs/Blank-black-screen-after-initial-power-on-bu...
Highlighted
JUMP TO SOLUTION
In my case, I have perfectly fine video and audio, and can control via remote, but I do not see any elements of the UI.  No volume level indicator or Home Menu.  I only use apps and a PS4 on HDMI1 on an NU8000.  No other input devices.
Soft power cycling via remote or TV power button resolves this UI glitch.
Highlighted
JUMP TO SOLUTION
Thanks for being SNARKY but it seems that thousands of customer are hving the issue so how about being helpful instead of "We already have this topic in another post.
Highlighted
JUMP TO SOLUTION
You do realise that I am the original poster of this thread right? I posted the problem, I then "snarkily" let people know that this issue has been reported elsewhere in case they wanted to follow that thread & I also posted that there was a solution coming.
FWIW, I actually worked directly with the Samsung software engineers to troubleshoot the problem, to help them replicate it on their TVs, so they could release a FW update to solve the problem.
Perhaps read the ENTIRE thread next time before posting a
Highlighted
JUMP TO SOLUTION
How long is the TV powered off before you get the black screen issue?
Highlighted
JUMP TO SOLUTION
I'm not exactly sure but I'd say perhaps 10-15mins. If you turn the TV off and on immediately, it's fine. Once a short period of inactivity passes, the power-on/blank screen issue kicks in.
Highlighted
JUMP TO SOLUTION
What devices are connected to the HDMI ports when blank screen issue happens?
Highlighted
JUMP TO SOLUTION
A user at RTINGS.com claimed the issue only occured in GAME mode. I ran some tests and can concur this is accurate. Even if nothing is plugged into the HDMI cable, if the HDMI port is assigned to GAME mode, the blank screen issue occurs. If GAME mode is turned off, the issue disappears. Definite software bug.
