One Connect Box Intermittent Noise
(Topic created: 12-11-2021 03:35 PM)
userl9dvRLiWdg
HD and UHD TVs
One Connect Box has a mechanical device inside (assume this is a fan or hard-disc) that starts to make a rotational noise when the power is first turned-on.  However, noise will normally cease after recycling power or thumping the top of the One Connect Box.  And once the noise stops, it normally doesn't return until the next time I turn the unit back on.
userl9dvRLiWdg
HD and UHD TVs
Several videos on You-Tube provide fairly easy process to disassemble the one-connect box so small cooling fan can be cleaned and lubricated.  Took only about 15 minutes to complete and this solved the problem.
userl9dvRLiWdg
HD and UHD TVs
userl9dvRLiWdg
HD and UHD TVs
As a follow-up, the TV (Model: UN78HU9000F - from 2014) displayed an error message several days after I first detected the fan noise, indicating there was cooling fan issue.  And this was probably triggered by an over-temp condition since the fan was not spinning effectively.  But error message ceased after cooling fan was cleaned and lubricated.
