- Mute
11-09-2021 11:08 AM in
HD and UHD TVsThe volume on my Plasma TV is struck, cannot lower or higher sound or mute volume either when using the remote or using the controls on the side of the Plasma Display
Solved! Go to Solution.
- Mute
11-09-2021 01:16 PM in
HD and UHD TVsThank you. This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: https://www.samsung.com/uk/support/contact/, or contact your regional Samsung Community here: https://eu.community.samsung.com/?category.id=uk.
- Mute
11-09-2021 12:15 PM in
HD and UHD TVsGood afternoon. I understand that having sound issues with your television can be frustrating. I have been unable to locate your model in my system. Was the TV purchased in the US?
- Mute
11-09-2021 01:05 PM in
HD and UHD TVsNo it was purchased in the UK
- Mute
