Power up issues
Have a Samsung UN55NU6900 TV. Currently running Software Ver. 1310. I just recently mounted the TV without using it for 6 months during a renovation. Red light flickers when power button on remote is pushed and TV flickers but nothing. After pressing button on TV a couple times I can get the Home screen. Never see the Smart screen start up any more. Could it have been due to a bad update?
1 REPLY 1
Re: Power up issues
I'm sorry to hear that, does this occur after unplugging and replugging the TV up? Also, does this occur with nothing connected to the TV?
