Remote sensor for an older business model TV?
(Topic created: 06-08-2021 08:13 AM)
userRXKDhJfsZO
HD and UHD TVs
Hey guys, not sure if anyone can help me with a very specific problem I am having. I have a 10 year old ME65B model at my job and there is no sensor on it (remote is not working). I have compared it to other TV's that are the same model an they all have sensors, except this one. I looked through the manual and they mention a sensor extension wire that can be used. The plug on the back say (IR / Ambient Sensor IN) and there is some mention of it in the manual. It is an older Korean model and there is no model number for the extension sensor ... I cant find it anywhere online. I attached a few photos. Anyone know a model number or possibly where I can find it?
Not applicable
HD and UHD TVs
LongHiker
Legendary Samsung Care Ambassador
HD and UHD TVs
Not applicable
HD and UHD TVs
userRXKDhJfsZO
HD and UHD TVs
Thank you for your help! So crazy that the part name doesn't have the word sensor in it. I ordered it.
Not applicable
HD and UHD TVs
You are most welcome.
userRXKDhJfsZO
HD and UHD TVs
Thank you!
