- Mute
04-21-2022 11:26 AM in
HD and UHD TVsSamsung Smart TV remote control on-off button and volume button do not work and all other buttons work.
Solved! Go to Solution.
- Mute
04-21-2022 01:04 PM in
HD and UHD TVsHello! I understand how this can a be cause for concern, just want to confirm have you made sure that your TV firmware is up to date? Also have you tried resetting your remote by taking the batteries out and holding down the power button for at least 10 secs?
- Mute
