Samsung TV Will not connect to internet!
(Topic created: 06-25-2019 12:23 PM)
user1XgP8SQ2HN
HD and UHD TVs
Samsung model UN55KU6600F
The WiFi has worked fine (with minor problems occasionally) until about a week ago now it will not connect.  It shows the 2 network names I currently use on my home network and have tried both at least 15 times.  The passwords ae entered correctly (event tried the WPS option 5 times) still it will not connect.  Any suggestions?
JUMP TO SOLUTION
SamsungJam
HD and UHD TVs
Oh no!  Can you provide the model of your television?
userGg4YIDw3bx
HD and UHD TVs
Good afternoon.
For some reason I am presenting connection problems. After an update, the tv wifi conection has been limited and it stops working onstantly, reducing the image quailty to the lowest. I have done internet tset on the tv and it only show 1 to 3 MB of the 50 MB I have on my internet speed. Ther rest of my things work fine. Please advise.
SamsungCaleb
HD and UHD TVs
I'm sorry to hear that, have you tried a factory reset on the TV? Also, are you trying to connect to 2.4ghz or 5ghz?
userGg4YIDw3bx
HD and UHD TVs
I have done the factory reset, but for some reason, nothing changed. I am ot sure what the router has, but I think it is 2.4 ghz.
Not applicable
HD and UHD TVs
If you are only seeing 1 - 3 MBPS at the television, your wifi signal strength or bandwidth is not adequate at that location. How far is the router from the television? Are there obstructions, like walls or floors, between the devices? Can you try connecting an ethernet cable between the TV and router to see if you get better performance?
useroK3qNql6Wj
HD and UHD TVs
i had error code 1000-7 and after doing alot it didnt work, so what i did was reset the whole tv and started from scatch and it worked take your time and follow wizard and u shouldnt have any problems.
SamsungJam
HD and UHD TVs
We're glad that you found a resolution!
