userbRwkQ7Lof6
Samsung TV remote will not work, displays "Locked"
JUMP TO SOLUTION
Last night, apparently randomly, both the cable remote and the native Samsung remote stopped controlling the TV. Pressing any button on either remote simply displayed "Locked" in a box on the screen.
There appears to be no manual on/off switch on my TV, unbelievably (model number UN46EH5000F).
The solution was to remove the TV from the wall, unplug it for a couple of minutes, and plug it back in. Both remotes now work as they should.
Does anyone know what is going on here? Is there some key combination on the remote to solve this problem? I don't want to be in the position of having to remove the TV from the wall again if this happens again. Thanks.
1 SOLUTION
Re: Samsung TV remote will not work, displays "Locked"
JUMP TO SOLUTION
This situation is caused by a signal issue from the Set-Top-Box (STB).
The only way to resolve this is to unplug the television for 30 seconds.
If it occurs again, I would recommend speaking with your cable company regarding a replacement STB.
8 REPLIES 8
JUMP TO SOLUTION
userbRwkQ7Lof6
JUMP TO SOLUTION
Thanks. Can it be dealt with by disconnecting the STB from the TV?
userbRwkQ7Lof6
JUMP TO SOLUTION
Second question: is this a fault in the STB? That is, if I replaced the STB, would I expect the problem to go away? Or is it just the way the particular variety of STB I have works?
JUMP TO SOLUTION
No, you would have to unplug the TV form the outlet for 30 seconds. It is possible the fault is with the STB, but contacting your cable company would be the best option to get a replacement.
userbRwkQ7Lof6
JUMP TO SOLUTION
Thanks again. I still have a question. So if I just go to my cable provider and ask for a replacement box, and they give me the same model, am I likely to have the same problem? I guess what I'm asking is: is there something wrong with my box in particular, or is there a bad interaction between that *model* of STB and my model of TV?
JUMP TO SOLUTION
That is what we are tying to test out. I can't say 100% the symptom will go away by getting a replacement STB, but replacing it would help us figure out the root cause of the symptom.
userbRwkQ7Lof6
JUMP TO SOLUTION
OK. I'll try that. Of course, this has happened only once in five years, so who knows.
JUMP TO SOLUTION
Please keep us posted.
