Samsung remote volume ⬆️ and ⬇️ button not working
(Topic created: 10-03-2021 03:46 PM)
Wonderfay
HD and UHD TVs
I have a Samsung TV model Un4m5300 and the tv remote volume button isn't working. If I hold up volume it will 24, 25 up 25, 24 volume. Not only that but xfinity remote doing same thing. I only have TV stereo and pcm under sound settings. I tried TV off and on then remove batteries and hold power button nothing is working. I don't want to get to frustrated so can you help please?
MsBri1
Neutron Star
HD and UHD TVs
Hello, If you have the smart remote you can follow the steps from this guide here Connect remote, or the guide for the remote not working properly here Remote not working or can even try replacing the remote itself and you can contact our parts department J&J international at 1-800-627-4368. I apologize for any inconvenience you've experienced.
user_ams007
Samsung Care Ambassador
HD and UHD TVs
Have you tried to tried to Repair the remote control to the TV
Wonderfay
HD and UHD TVs
How do I do that?
HD and UHD TVs
Check your available hard drive space. I had this exact issue when it was full.
MsBri1
Neutron Star
HD and UHD TVs
Wonderfay
HD and UHD TVs
Thank you all I ended up getting new remote through amazon
