userHrWGUzZhFO
Samsung smart hub web browser problem
JUMP TO SOLUTION
I have this problem where my internet is very good, but when i go to the web brower session and opened it, only google and bing works and other shows, server not found, pleaes check the following
please help me guyss
1 SOLUTION
Re: Samsung smart hub web browser problem
JUMP TO SOLUTION
@userHrWGUzZhFO: We can only support US products. Please contact Samsung Support in your region: http://bit.ly/lBD2zm
8 REPLIES 8
JUMP TO SOLUTION
Please provide the full model code and current software version.
userHrWGUzZhFO
JUMP TO SOLUTION
my tv is a samsung smart tv ua55d8000 and it connects to the internet but when im on web browser it shows server not found, Im from Myanmar
JUMP TO SOLUTION
userbrd4YnxhTt
JUMP TO SOLUTION
Hello,
I have the same problem with a Samsung UE32D6500 with 001013 software version.
Please help
user4AWdPvkRzp
JUMP TO SOLUTION
the model UN48JU6700
JUMP TO SOLUTION
Good afternoon, Just to confirm, are you having a problem browsing the internet through the web browser? Are you having any trouble with the other apps as well?
usergpFjxJnvRs
JUMP TO SOLUTION
Hello, I have this problem.  Can youadvise what solution was.
userQ6rIxHkuot
JUMP TO SOLUTION
Samsung  is not that great anymore. I have the same problem  there is no solution to this problem
