Highlighted
Screen Overheating and corner of frame melted
Hello, the screen and corner of the frame of my TV melted. The TV is inoperable. This seems not only like a hazard, but some thing that should NEVER happen. I think we are lucky that nothing caught on fire. What will Samsung do to fix this?
1 REPLY 1
Highlighted
Re: Screen Overheating and corner of frame melted
I would be more than happy to look into this for you.  Could you send me a private message so that I can get some additional information?   http://bit.ly/2ihPL97
