Shortcut in smart hub keeps disappearing
(Topic created on: 4/19/21 8:43 AM)
PaulKK
HD and UHD TVs
Hi to all,
I have a TV Q90T and quite satisfied with it. But recently I've stumbled on an annoying issue. The situation briefly is the following:
I have dlna server on my router (with attached hdd) and watch movies with embedded dlna player on TV. I add a shortcut to home (smart hub -> sources -> "dlna server's name" -> add to home). It appears in the bottom line with the other shortcuts (youtube, netflix, etc.). However, after turning TV off and on again this shortcut is removed. I place it again, and it disappears on the next turn on. Moreover, I can see the shortcut right after turning the TV, but after 2 secs the TV removes it from that bottom line.
Firmware of the TV is the newest - 1497.
Tried resetting the tv - nothing changed.
Can someone through an idea?
userKxfSyIjYwJ
HD and UHD TVs
Same thing is happening to me.  Newest firmware, shortcuts are disappearing.  Noticed problem with network connection after trying to load Netflix.
PaulKK
HD and UHD TVs
Anyone? Any solution?
