- Mute
‎07-10-2023 12:55 PM in
HD and UHD TVshi everyone - i have a Samsung Smart TV, circa 2017 - it's started showing a connection to a 'new' wifi network - this network also appears as a network option on the house phones and tablets - the network calls itself Back door tv.v and a quick google suggests it's some sort of hack, using the tv to spy?
anyone know much about this?
should we be worried? is there a way to remove it? (i've disconnected the tv from the wifi, for now).
tia for any advice, Patrick
Solved! Go to Solution.
- Mute
‎07-10-2023 01:28 PM in
HD and UHD TVs- Mark as New
- Mute
- Mute
‎07-11-2023 01:27 AM in
HD and UHD TVshi, thanks very much, that seems like sound advice!
- Mute
‎07-11-2023 01:37 AM in
HD and UHD TVs
