Highlighted
Smart TV connect DVD player via coax cable
JUMP TO SOLUTION
Model UN436900 FXZA. My only option for connecting my DVD player to the TV is by coaxial cable. How do I get TV to recognize this source?
1 SOLUTION
Highlighted
Re: Smart TV connect DVD player via coax cable
JUMP TO SOLUTION
So the Samsung Moderator and I have communicated via email, and the answer is that a converter is required because "The TV is not capable of reading the signal from the DVD player via a coaxial connection". Either a coaxial to HDMI converter or RCA to HDMI should work since my DVD player has both, and I suspect that the RCA sound and video connections would give the better picture.
4 REPLIES 4
Highlighted
JUMP TO SOLUTION
I'm sorry to hear that, have you tried to connect another device to the TV? Also, have you tried a different HDMI?
Highlighted
JUMP TO SOLUTION
OK Caleb, let me see if I can better explain the situation. The ONLY way I can attach the DVD player to my TV is via the cable/antenna fittings. That's because my TV does not have any jacks for component video, etc - just HDMI & UBS. Unless there is some way to convert the DVD video/component output to an HDMI cable, my ONLY option is to use the "Antenna IN" connection. To answer your question, I have connected my laptop to TV via HDMI, but that has nothing to do with this problem. Also, I have no reason to think that my DVD player isn't working, since it worked fine with my previous TV. Thanks.
Highlighted
JUMP TO SOLUTION
Please send the full model number to this PM Link.
Highlighted
JUMP TO SOLUTION
