Surround Sound No Longer Working !!!
(Topic created: 06-22-2021 01:59 PM)
userG8cUlwiPgz
HD and UHD TVs
Greetings and Salutations !!!
I just bought a new Samsung 75 Inch 4K Crystal UHD Smart TV 75AU8000 and I re-wired it to my Denon 1312AB the way my old TV was set up.
For some reason, I am not getting ANY sound through my surround system ... only the sound from the TV itself.
I connected my Digital Audio Optical Cable to the back of the TV as it was on the old TV. Did the technology change and I need a new cable ?
Am I doing something wrong?
KwikOne
HD and UHD TVs
No, you aren't doing anything wrong. Either the cable, the TV, or your surround system has a problem. In order to isolate the problem component you will need a new cable, TV, &/or surround system. First try your old TV and see if it works; if it does the problem is with your new TV; if not then the cable has become bad. If it does then the problem is with the new TV; Perhaps some setting in the TV (since I don't have the specifications of you new one this is a wild guess). Best of luck on your troubleshooting.
SamsungLou
HD and UHD TVs
Please check the speaker selection in your audio settings, and make certain Digital Audio Output is selected.
