TV Plus guide is not correct.
(Topic created: 07-20-2021 09:51 PM)
userGQKlhyS91Z
HD and UHD TVs
  • When I go to the TV Plus guide the program information is not correct.  The guide shows the info for each channel, but if you go to that channel a different program is playing. Any ideas.
1 Reply
SamsungTam
HD and UHD TVs
Hello! I do apologize for the inconvenience this has caused. Have you tried to reset the unit?
