userQtHDJBvi9i
TV WiFi problem even if I reset everyday.
Bought a Samsung UE49NU7500 only 3 months ago. Everyday the WiFi disconnects and there is no issue with my router (It engineer), I simply have to go to settings and reset network then reconnect to WiFi typing password each time.
I reset everyday now, I watch a lot of Netflix.
Before posting here I tried heaps of solutions.
1 REPLY 1
Re: TV WiFi problem even if I reset everyday.
Thank you so much for reaching out! This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: https://www.samsung.com/us/common/visitcountrysite.html. Thanks!
