TV model UN65MU630D doesn't see AV Signal
(Topic created: 11-09-2019 05:09 PM)
userhXO2KMbZT5
HD and UHD TVs
Hi,
The TV keeps on saying "No Signal" when plugging a DVD player trough the AV Component connections. It knows that something is connected, as an icon "Component" is showing among the sources.
- I am using a Red/White/Yellow connector turned into jack, plugged in teh Yellow jack behind the TV.
- I have two DVD players, neither of which is detected
- Adding a Blue/Red connection through the other jack does not improve the detetction.
- The software is updated to the latest version.
The TV keeps showing "No Signal" connect or click on Source. To no effect. I have tried about any connection possibilities or website information.
Thank you for any advice you could suggest.
JUMP TO SOLUTION
SamsungGill
HD and UHD TVs
Please keep us posted.
userhXO2KMbZT5
HD and UHD TVs
Bought a new cable. The DVD is detected, the image is good, but the sound is awful. This being said, I think the sound problem resides in teh DVD player.
Problem is solved.
SamsungLou
HD and UHD TVs
That is great news.
