Highlighted
TV switches back to Antenna input when power up
JUMP TO SOLUTION
My 80 year old neighbor who is a widow, called me yesterday to look at her Samsung TV. When I got there the source was set to Antenna input.  The screen was snowy and said there was no input.   She has Dish and it is connected to an HDMI input.  I changed the input source to "HDMI", but when the TV is powered down and back up it goes back to the Antenna  input. Not sure why this started happening as she has had this TV and Dish for a good while.  The only thing connected to the TV is the Dish box to an HDMI input. How can this be fixed?
I just spent an hour on Samung Support site.  Absolutely no help.  The only thing that I learned was that Samsung TVs have automatic switching, which I was not aware of.  Can someone explain how this automatic switch works?  In my neighbor's setup, is there a way to force the TV to alway default to the HDMI input when the TV is powered up?
1 SOLUTION
Highlighted
Re: TV switches back to Antenna input when power up
JUMP TO SOLUTION
Thank you. There are several things to check. First, make sure the TV software is up to date by going to Settings>Support>Software Update. If there is an update, it will install and restart the television. If not, unplug the television for 5 minutes, then reconnect and try again. Finally. with the television on, point the remote at it and enter this sequence - Mute, 7, 2, 9, Exit. You will not see a verification on the screen, so testing would be power off an on again.
Please let us know if any of this helps.
5 REPLIES 5
Highlighted
JUMP TO SOLUTION
We are sorry to hear about this. Can you please provide the model number for the television?
Highlighted
JUMP TO SOLUTION
Samsung Model UN40H5003AFXZA
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
When I returned to check those suggestions, another neighbor had resolved the problem and I don't know what they did.  Thanks for your help and I will retain those suggestions if the problem occurs again.  I will mark this as solved.
Highlighted
JUMP TO SOLUTION
You are most welcome.
