The sound on my Bluetooth Headphone does not synchronize with my TV speaker
(Topic created: 02-07-2023 05:50 AM)
RaymondW
HD and UHD TVs
I today managed to pair headphones to my 7100 series TV and to get sound from the TV speaker at the same time.
However, the sounds from my headphones and the sounds I get from the TV speaker do not synchronize (I pick up both sounds!).
Help will be appreciated.
userONOSGYvrXr
Cosmic Ray
HD and UHD TVs
Audio streaming via Bluetooth will be slightly behind and out-of-sync due to the encoding and decoding process. You can go into the sound settings and adjust the audio delay, but that will likely affect the optical output.
1 Reply
userONOSGYvrXr
Cosmic Ray
HD and UHD TVs
