- Mute
- Email to a Friend
2 weeks ago in
HD and UHD TVsBought this TV in november 2020 and all of a sudden the remote will not work with my altice cable box. Is there a fix for this or do i have to bite the bullet and get a universal remote? This is extremely aggravating as dont want to use multiple remotes. As i researched it seems as it may have been a firmware update.
- Mute
- Email to a Friend
a week ago in
HD and UHD TVsI'm sorry to hear that, have you tried to reset your smart hub? Also, have you made sure to reset your remote by taking the batteries out and holding down the power button for at least 10 seconds?
- Mute
- Email to a Friend
a week ago in
HD and UHD TVsYes. The remote works fine with the tv but no longer controls the set top box after the tv received an update.
- Mute
- Email to a Friend
12 hours ago in
HD and UHD TVsHow do you have everything connected?
