userqZax9eUDIA
UN55MU8500FXZA will not turn on- red light blinks then screen blinks and repeats over and over
JUMP TO SOLUTION
Hard to believe a TV I spent $2000 on a year and a half ago will not even power on. Any help or suggestions would be appreciated.
1 SOLUTION
userqZax9eUDIA
Re: UN55MU8500FXZA will not turn on- red light blinks then screen blinks and repeats over and over
JUMP TO SOLUTION
This POS is being picked up for the trash and I have purchased an LG in its place. Thanks!
7 REPLIES 7
JUMP TO SOLUTION
Have you tried unplugging the unit for 5 minutes? Have you tried plugging it directly into the wall outlet?
userqZax9eUDIA
JUMP TO SOLUTION
Yup.......unplugging an electrical device is this the goto move
userqZax9eUDIA
JUMP TO SOLUTION
I will NEVER buy Ssmsung again
JUMP TO SOLUTION
The symptom you described is a power cycle. This is sometimes a result of a software update that does not download properly. Unplugging the television for a set time performs a sort of soft reset that helps with resolving the symptom if it is software related. Since it did not resolve, it is a hardware symptom and would require service. I would be happy to set that up for you but it would be an out of pocket cost.
userqZax9eUDIA
JUMP TO SOLUTION
userG8JPd2bQec
JUMP TO SOLUTION
A service which I will have to spend more money to try to “maybe” get it fixed or not??
JUMP TO SOLUTION
@userG8JPd2bQec   We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
