USB and HDMI ports on Samsung - 40" Class (40" Diag.) - LED - 1080p - Smart - HDTV
(Topic created on: 4/11/21 1:10 PM)
userRCVXfkBGl4
HD and UHD TVs
My Samsung Smart HDTV is about 5 years old and it is mounted. I wanted to add a roku stick and I am having trouble locating where the HDMI or USB ports are. Per the pictures is equipped with them, as most smart TVs have been for many years. See here (https://www.bestbuy.com/site/samsung-40-class-40-diag--led-1080p-smart-hdtv/6422016.p?skuId=6422016).
But I searched the sides, top, and bottom and don't see any. Is it possible they are in the back middle right where it is mounted? I wouldn't think so as that would be a pretty silly design idea. Anyway is there some plastic compartment that opens because otherwise I don't see any. Thanks.
1 Reply
SamsungLou
HD and UHD TVs
The ports on your television are recessed into the right hand side of the back.
