userPc7QpBSAp5
Very loud fan noise on Samsung tv
Every once in a while, for no apparent reason, my Samsung TV will begin making a very loud humming/buzzing noise that sounds as if it might be coming from the fan. I turn the tv off, wait for about five or ten minutes, turn the tv on, and the sound is gone. The tv is not too close to a wall, there is plenty of room for air circulation, it is on a stand, not a mount, and it is not an issue with the sound itself.  Any ideas?
1 REPLY 1
Re: Very loud fan noise on Samsung tv
We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
