03-07-2019 10:09 AM
Smart TV: UE55MU6475U
Smart Remote: BN59-01270A
Sound: Logitech soundsystem, connected by optical
Problem: I can't use the volume when i'm using HDMI equipment (Playstation, Wii and so on). The volume are working perfectly when i'm using the Direct TV and all the Samsung Apps.
I have connected the Smart Remote to the Logitech soundsystem, so when i'm using the volume. The remote will ajust the volume on the Logitech soundsystem and not the Smart TV.
I have tried to connect the remote when i'm using the HDMI equipment, but then the volume dosen't work when i'm using Direct TV or the Samsung Apps.
Please help, what to do? - Should it be possible to to use the Samasung Smart Remote to edit the volume on the Logitech soundsystem when i'm using Direct TV, Samsung Apps and HDMI equipment?
Solved! Go to Solution.
03-07-2019 10:16 AM
Regrettably support for non-US models is very limited. We suggest reaching out to a support team in your area for further assistance. You can do so by using the following link: http://www.samsung.com/visitcountry Thanks!
03-07-2019 10:16 AM
