HW-MS650 - Not powering on automatically with TV.
Soundbar does not automatically turn ON when I turn the TV on, it does, however, turn off when I turn the TV off.  Have to use the soundbar remote.  My other SM Soundbar turns on automatically when the tv is turned on, not needing to use the Soundbar remote separately.
Setup:
TV (UN65NU8000) - Connected via HDMI ARC to the HDMI ARC Port of the MS650 Sound bar ,  Directv Cable box connected to the HDMI IN on the soundbar.
Re: HW-MS650 - Not powering on automatically with TV.
Have checked your tv to see if the HDMI CEC is turned on? On the TV; Using the TV remote, navigate to Settings, select General, and then select External Device Manager. Select Anynet+ to turn it on.
I checked the External Device manager the Anynet (HDMI-CEC) is highlighted green. Any other suggestion?
