HW-MS650 Soundbar stuck on D.IN
After a power dip my soundbar is stuck on D.IN. Can't change this to WIFI, BT or one of the other functions.
Removed all cables for a few minutes. It comes back with only the D.IN mode.
Any ideas?
Re: HW-MS650 Soundbar stuck on D.IN
Have you tired resetting the sound bar?
Is there an other way to reset the soundbar?
I removed all cables including the power.
Is there anything connected or blocking the D.IN port?
No.
Can I get some more advice pls. Got a totaly not working soundbar here
To reset the sound bar please follow these steps.
1. Power On the Soundbar.
2. Press and hold both the Vol- and Vol+ buttons on the soundbar until INIT appears on the display.
Hello Marcus-Rex, just checking in to see if you were able to complete the reset?
I'm having the same issue with my sound bar. I reset it just like you said to do and it still isn't working. After resetting it what it supposed to happen because all I'm getting is D.IN?
[ Edited ]
As above,
Unplug the soundbar. Press the power button a few times so that you drain what ever power remains in there.
Wait another few mins. Replug the soundbar. Press and hold + and - volume keys for about 10 seconds until it displays "INIT" - "BYE"
Hopefully this works.
I'm ready to throw my MS650 off a 50 storey cliff due to ongoing HDMI ARC issues which Service 2 level from samsung cant fix.
