Sound cutting in and out when using vudu 4k hrd movie
When I watch movies in Vudu in 4k HDR the sound Cuts in and out. I spoke with Vudu and they said everything is right on their end. When I watch 4K movies on other sources such as Fandango now or Google Play movies everything is fine do you know when it'll start working for Vudu?
See more topics labeled with:
Re: Sound cutting in and out when using vudu 4k hrd movie
What device are you watching the movies on?
I have an nu7100 55in and I'm using a Vizio 4.1 Dobby sound bar connected through an HDMI Arc. When I watch movies in 4k hdr on Vudu the sound Cuts in and out but when I use other services such as Fandango now or Google Play I don't have any issues.
Does this happen with non-4K video? Are you using a 4K rated HDMI cable?
Only happens on 4K in Vudu everything else is fine and yes I'm using a 4K HDMI cable. When I'm washing high-def programming or standard definition programming I'm not having any sound problems
Please send your model and serial number to this PM Link.
I haven't heard back from you about the sound problem do you know any thing new?
