Highlighted
2500W Giga Sound System MX-HS8500
I have been trying for months to get my system repaired trying to figure out the piece that I need I have called Samsung and nobody seems to be able to help me so if you have a stereo like the one I just post the Samsung beat sound system I am looking for the pieces that goes on the end of the cord that runs from the subwoofer to the main box they are plastic plugs that goes into the main system to make the speaker's play 2 is purple one is white one is red
Someone pulled the wires out of the connectors that goes into the main system I need to know the pieces that I need to buy to replace.
1 REPLY 1
Highlighted
Re: 2500W Giga Sound System MX-HS8500
Can you please provide a picture of the cable and connectors?
