usereaqpHq9DAJ
Re: HW-K950 rear speakers not working even connected to the soundbar
I have the identical problem...did Samsung ever send a solution?  Looks like the thread just ended.  My soundbar is <15 feet in the same room with a line of sight to the speakers, and it all keeps disconnecting
coolin
Nope, it's not a Samsung problem according to them.
userWt276lIk6v
My k950 has started to do the same, subwoofer loosing connection randomly. Nothing has changed in the room .
Is there anything else in the room that has open Bluetooth?
userLE9RMwuN0P
I have had this problem for quite some time..
userJcvtrVvq7F
Cosmic Ray
Would you mind tell how an HDMI cable can make the subwoofer and speakers disconnect?
@SamsungDarius wrote:
It is possible the HDMI cable may be causing this symptom. Have you tested out another HDMI cable for the device?
coolin
Re: HW-K950 Subwoofer and rear speakers disconnect randomly
I expericence the sub drop outs pretty much daily. Mostly happens in Spotify connect but it has happened while waytching TV or a movie. Samsung's "updates" have yet to fix this issue.
