HW-Q90R low subwoofer volume on 1012.6
(Topic created: 06-16-2022 05:29 AM)
scanarch
Home Theater
Hi!
I have updated my HW-Q90R soundbar to the latest firmware and although it has helped out with rear speakers being too quiet, it has also made my subwoofer sound really weak.
Even when setting Woofer to +6, you can barely hear it.
I tried restarting, reinstalling the firmware, but it all remains the same. Previously it would work fine, you could "feel" the bass easily.
Is there any option to downgrade firmware for subwoofer only or is there any fix for this issue?
I have seen plenty of posts regarding this issue on EU community, but non here.
1 Reply
userJVcZP89ab4
Home Theater
I have the same issue. testing my set up with my Visio sound bar the bass is much higher at half the base volume on that system. it has a smaller woofer, and a lower power rating. following to see if anyone has found a solution to this.
