Highlighted
HW-R650 remote not working, subwoofer won’t connect either
JUMP TO SOLUTION
I got this soundbar system yesterday afternoon. The remote it came with is not working. I put new batteries etc. it will not connect with the soundbar- and because you need the remote to connect the subwoofer to the soundbar, I cannot have bass now. I have the soundbar connected to my 58" class 7 4k by HDMI arc- it's the only way I was able to tell the soundbar works.
what do I do about the remote?
1 SOLUTION
Highlighted
Re: HW-R650 remote not working, subwoofer won’t connect either
JUMP TO SOLUTION
I would contact the retailer and see if they can look into why it's not working properly or if you purchased a returned model.
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
I had it exchanged. The new one I have now works fine so far!
Highlighted
JUMP TO SOLUTION
That's awesome to hear! If you have any questions or concerns in the future, just reach back out and we'll be happy to help! Smiley Happy
