How to disable "Auto Power Down" on HW-A550 sound bar
(Topic created: 07-24-2021 03:10 AM)
TonyBennett
Home Theater
I've recently purchased an A550 sound bar.
Its documentation says it will automatically power down after 20 minutes of no audio.
I read elsewhere on the Samsung community that this feature is able to be disabled/re-enabled by "auto power down" function on some soundbars.  The A550 documentation doesn't mention that feature.
Is it supported.. and if so what is the key sequence to access it..?
1 Reply
SamsungLou
Home Theater
Good afternoon! I am sorry, the auto power off on this model cannot be disabled.
